wall intersections
why my walls not intersection?
4 REPLIES 4
I'm not an expert, but, did you check your materials and materials priorities?
make sure you're using the same materials in both wall, at least in the core, and check materials priorities, if they have the same priority they should join nice.
yes same material and same priority value. i really dont understand why looks like this
ok, maybe is the cut plane? those are doors I can see there?
If not, lets wait that someone who knows answer this, I would like to know the answer to this, just in case it happens to me too.
Kamelite
How are Your Reference lines? If i'm not mistaken, they have to be on the same side of the wall, in this case on the outter side....
.Thag
Windows 10, Archicad 28
