wall lines are not visible
Palmm
Core lines are not visible on the composite wall I drew. Can you help me
3 ACCEPTED SOLUTIONS
did you try changing these to white
Archicad 26, build 3001
Montenegro
only the lines inside the core are not showing. Only plaster lines are visible at the moment. The lines of the wall are not visible
The solution is İKİKALEM in architecture. Model display options with black base should be corrected. As seen in the photo
9 REPLIES 9
DGSketcher
Legend
Check you haven't got a Graphic Override active that has the "Hide Skin Separators" turned on.
mija
What happens when you change them to white?
Montenegro
normally it should be like the photo below. I checked the graphics enablement, there is no problem. How can I solve this?
Is it your Partial Structure Display settings - i.e. showing core only?
Montenegro
i tried different color combination but result is same
That is the automatic pen colour visibility.
Me personally, I would never use a black background.
