‎2023-08-22 11:58 AM
‎2023-08-23 09:12 AM
did you try changing these to white
‎2023-08-23 02:22 PM
only the lines inside the core are not showing. Only plaster lines are visible at the moment. The lines of the wall are not visible
‎2023-08-23 03:45 PM
The solution is İKİKALEM in architecture. Model display options with black base should be corrected. As seen in the photo
‎2023-08-22 12:36 PM
Check you haven't got a Graphic Override active that has the "Hide Skin Separators" turned on.
‎2023-08-22 12:41 PM
What happens when you change them to white?
‎2023-08-22 05:07 PM
normally it should be like the photo below. I checked the graphics enablement, there is no problem. How can I solve this?
‎2023-08-23 02:51 AM
Is it your Partial Structure Display settings - i.e. showing core only?
‎2023-08-23 02:23 PM
i tried different color combination but result is same
‎2023-08-24 03:08 AM - edited ‎2023-08-24 03:08 AM
That is the automatic pen colour visibility.
Me personally, I would never use a black background.
