wall under stairs
good day,
Can some one talk me through on how to trim a wall to a stair case (on the right side of the stairs), so that the lower part of the stairs is filled with a wall and the top part is open
Many thanks for your help
Hugo
7 Replies 7
Through Solid element
Srinivas
Design > Solid Element Operation
1) Select the Stair and make it the operator,
2) Select the wall and click on the target object button.
3) Action - Subtract with upward extrusion
4) execute
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
Many thanks !!! work the treat
4) execute
can you explain it a little more? because i dont understand exactly the procedure
thanks
Just do as explained and it works fine
Srinivas
thanks
Wendy,
Check this one
http://www.aecbytes.com/tipsandtricks/2006/issue10-archicad.html
ArchiCAD Service
Mac, Windows 11
thank you very much!!! thats perfect! 🙂
