walls disappearing in 3d
have a model with alternate layouts, some have the same wall position but on different layers. Each time this is done, the wall will disappear in 3d, but show the door (if inset) or show the intersection of the layer turned off. Despite 1 layer being turned off. see pic
[/img]
3 Replies 3
rjwilden
Try undoing trim to roof SEO then re trim with the old way we use to do it. In my view this is a bug. Has happened to me on a number of occasions. Can never reproduce it.
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
If the walls are in different layers then make sure those layers have different intersection priority numbers in the layer settings.
Remember to save them in your layer combinations as well.
This way the walls won't intersect with each other - which they will do even if you turn a layer off and the layers have the same IP number.
cheers guys
