walls intersecting
Hello.
I have several types of walls, as shown below, and I have trouble intersecting them properly.
In picture 1, for instance, the walls overlapping the ones with insulation belong to an inferior intersection group (1 versus 2) and have a building material whose priority is smaller. I do not understand why this overlapping.
What should I do?
Thank you.
1 REPLY 1
David Maudlin
igreere:
Since the Walls area on layers with different intersection groups, they do not interact. You should use the Display Order to send the solid walls back in the order.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
