walls
Please help me with this wall. As the picture show below, I need to building it in ArchiCAD. I don't know how to build a wall tilted in angle.
31 Replies 31
Eduardo Rolon
check under Extras-Accesories-Wall Extras.
If that does not help you, you can read the following post
Re: GDL Import from DWG Block
in the library forum
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
actually I did try wall extra, but it doesn't work.
I'll read the other post. Thank you
Although there is some detail to work out in the final model, you create tilted walls by drawing a thickened wall. Use the profiler add-on to create a shape to subtract from the wall using the solid element operations.
HTH
Richard:
This is exactelly what I want for this 3d model rendering, but I didn't get the idea of step 2. Could you tell me where can I find the profiler to add-on to create a shape to subtract? Thank you for your time and help
my boss doesn't want me to attach picture on the website, so I have to delete the picture from here. I am sorry if this is the problem.
You can load it by using your Add-On Manager located in the tools menu. When that opens, go to Edit list of available add-ons >> click on search for more add-ons. The Profiler Add-on is located in the goodies folder of your ArchiCAD application.
There is another string in the Working in ArchiCAD forum http://archicad-talk.graphisoft.com/viewtopic.php?t=2694 that has some further discussion on tilted walls. If you haven't checked it out, it would be worth your while as there are some issues associated with tilted walls including plan view representation, window and door frames....
HTH,
Happy Friday!
Thank you for your help. I did also check that forum. But I have more problem to make it work.
Richard:
Is Add-On Manager can find in ArchiCAD 7.0? Because I couldn't find that option.
ashley wrote:
Richard:
Oh no...7.0....Tools menu >> "Load Add-on" Then, browse to Goodies folder...
but this will not help you...There is no solid element operations in 7.0. for step #3 Sorry...
Upgrade!
