‎2006-06-01 06:33 PM
‎2006-06-01 07:07 PM
‎2006-06-01 07:22 PM
David wrote:Interesting...so .PLC is an optional file when doing teamwork! Thanks David. I guess my next question for teamwork is...Should the views in plotmaker be directly imported from the .PLP file? And also....what becomes of the .PLN file from which the shared project was derived from?
The .PLP file is the shared file that everyone signs into.
The .PLC file is the local draft file that is optional, but I would recommend, for each individual user. Each user working on a .PLC then needs to do a send and recieve to update the PLP.
Also consider signing in as a task, such as "Electical Guy" and "Wall Section Guy" instead of Joe or Jane. Then you can tell who ever to open the Electircal Guy .PLC and fix the electrical stuff.
‎2006-06-01 07:40 PM
I guess my next question for teamwork is...Should the views in plotmaker be directly imported from the .PLP file?Now this is more interesting. Yes they can be. I suspect most do it this way. But a more bullet proof way is to save the .PLP out to a .PLN and link to that to the Layout Book. This way if anything ever happens to the .PLP you have a something to fall back on. Someone can link up the Layout book independent of PLP. The downside is that it is a small extra step to overright this .PLN.
And also....what becomes of the .PLN file from which the shared project was derived from?The beggining .PLN and for that matter the old .PLC's can be purged when you are done using them. Maybe a Project Trash folder if you want to keep everything.
‎2006-06-01 08:03 PM
‎2006-06-01 08:08 PM
‎2006-06-01 09:45 PM
Eric wrote:Method 1 seems great! no extra files floating around...straight to the point.
We have for many years been
Method 1:
1. linking drawings directly to the PLP
2. Not using draft files (PLC)
3. deleting the PLN file immediately upon creation of the PLP
Method 2:
1. Save the PLC
2. S&R to the PLP (and get the other team members to do it also)
3. Sign into the PLP
4. Save the PLP to a PLN
5. Open the LBK
6. Update drawings (from the PLN)
‎2006-06-01 09:51 PM
‎2006-06-01 09:59 PM
TomWaltz wrote:Good point
Don't forget that in AC10, the whole "LBK" step goes away and it's all in one file. At that point, it would seem silly to have a separate PLP and PLN.
‎2006-06-01 10:18 PM
junior wrote:There should be a few dozen by nowTomWaltz wrote:Good point
Don't forget that in AC10, the whole "LBK" step goes away and it's all in one file. At that point, it would seem silly to have a separate PLP and PLN.![]()
Another reason added to my list for wanting to switch to 10!
