where did Intersect w/ Line Extras shortcut go?
Erika Epstein
I've been meaning to ask this for some time...
Under "Tools", "Line Extras" is the "intersect" option. For years I have used this often enough that I long ago customized my windows toolbar with a shortcut icon.
Somewhere along the line since the advent of AC8 the option to have "intersect" put on the windows tool bar as a graphic shortcut was deleted. It is also not possible to create a shortcut key for it.
Or am I missing something here?
(wouldn't be the first time)
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
7 REPLIES 7
TomWaltz
Erika
I'm not sure about Windows, but on the Mac Version, you can create a shortcut for any Menu Pull-down command. You just select the "folder" it's in on the Customize - Keyboard Shortcuts menu, and you should be able to see it.
-Tom
Tom Waltz
Erika Epstein
Tom,
I have been through the keyboard shortcuts creator many times and just reviewed it again.
It is in front of my face, but where?
I have been throught each item on all the tabs and I am not seeing anything for "line extras" or "intersect". Could you or someone on windows perhaps post a screen shot so I can see what is front of me that I am not seeing?
(can't see the trees for because the forest is in the way...)
thank you
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Eduardo Rolon
In the tab for "menu commands" go down in the menu pull down until you see "TOOLS" after tools you will see "-line extras" select this one and in the command window you will then see "intersect"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Erika Epstein
erjolon,
thank you, but I am trying to create a SHORCUT KEY for the intersect line-extra tool.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Erika:
ejrolon was correct. But you have to go to "Open Keyboard Shortcuts" first, and THEN go to Menu Commands tab. You'll see a "Menu" drop down box. The Line Extras are there, just under "Tools". Just select the Line Extras line (not Tools) and you'll see the commands ready to have shortcuts assigned.
Richard
AC26 (since AC6.0), Win10
Erika Epstein
Ejrolon & Richard,
I can't thank you enough!
I didn't realize that was a drop down menu.
Yet another embarassing moment in my life.
Thank you again
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Erika Epstein
I'm so happy!
thanks again
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
