‎2011-09-06
10:43 AM
‎2023-05-25
05:43 PM
Rubia Torres
‎2011-09-06 11:14 AM
‎2011-09-06 11:43 AM
‎2011-09-06 07:33 PM
‎2011-09-07 03:53 AM
pixpast wrote:The first column shows you the height of the storey above/below project zero.
would it not be better if each level just had one imput number, seems to be double up for no reason, having both number columns ?
Ian
‎2011-09-07 03:18 PM
‎2011-09-07 03:49 PM
‎2011-09-07 07:49 PM
pixpast wrote:Just to correct you - All elements are placed relative to a storey level. If you change the level of the storey in that dialog box, everything relating to that storey will move with it - slabs, walls and columns.
...But on the other hand, the elements like columns and walls, not attachable to levels.
ie. the real idea of BIM, change my slab level and all my columns and walls will follow.
