window sill doesn't trim wall on storey below
Gary Hudson Jeffrey
Window sill doesn't trim wall on storey below. This is a problem where the window sill is at floor level. Is there a possible easy workaround?
ArchiCAD 64 20 Solo
Windows 7 Pro 64 bit
Intel Quad Core i7 3770K
16GB RAM
2GB Nvidia Quadro K2000D
HP Designjet 510 24” colour printer
4 REPLIES 4
Could you post an image of the problem?
Gary Hudson Jeffrey
Hi Laszlo,
How do I add an image without exceeding file size?
ArchiCAD 64 20 Solo
16GB RAM
Is it a separate wall on the storey below?
If so the window in the wall above will have no effect on the wall below.
You will either have to add in a separate opening or make the wall a multi-storey wall by setting the overall height needed and setting it to d\'Display on all relevant storeys'.
Screen capture programs are the best way to take a snap-shot with an image size small enough to post.
Gary Hudson Jeffrey
Thanks Barry. Yes, a separate wall on storey below & obviously I can't do this. Will take your advice & thanks for help on the snap-shot.
Gary
ArchiCAD 64 20 Solo
16GB RAM
