Quirk
windows in legend not on floor plan
Some windows have appeared in the window legend but are not on the floor plans—they seem to be duplicate windows. How does one find, and eliminate them?
AC 29 USA
macOS15.5
2.6GHz
1 Solution
Quirk
This worked great. I knew there was a simple way of fixing this. Thanks
AC 29 USA
macOS15.5
2.6GHz
Go to post
2 Replies 2
By "legend" I assume you mean "schedule".
If so, select the window you think is a duplicate and press the 'select on floor plan/3D' button.
Or you could use the 'Check for duplicates' add-on - it is part of the 'Goodies' add-ons if you do not already have it loaded.
Quirk
AC 29 USA
macOS15.5
2.6GHz
