windows in legend not on floor plan
Quirk
Some windows have appeared in the window legend but are not on the floor plans—they seem to be duplicate windows. How does one find, and eliminate them?
AC 23 USA
macOS 11.6.1
2.6GHz
This worked great. I knew there was a simple way of fixing this. Thanks
AC 23 USA
macOS 11.6.1
2.6GHz
By "legend" I assume you mean "schedule".
If so, select the window you think is a duplicate and press the 'select on floor plan/3D' button.
Or you could use the 'Check for duplicates' add-on - it is part of the 'Goodies' add-ons if you do not already have it loaded.
AC 23 USA
macOS 11.6.1
2.6GHz
