wireframe in photorendering projection
how can I create a photo rendering "just" with wireframe ?
Jens
Ben Odonnell
You can't,
But you can simply switch to wire frame mode in you 3D window and save out an image.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
View Sets also remember the status of the 3D window. So you can save a wireframe view to a View Set to bring into Plotmaker.
That being said... the picture below is a wireframe view, saved as a DXF, opened as a library part, viewed in the 3D window and rendered with the Sketch rendering engine!
Woody
Dwight
pass the crayons.
Dwight Atkinson
