We value your input!
working in 10 - broken in 11
settings for door/window
construction method 3rd
cavity closure - none
turn plaster - off (both sides)
a correct result
incorrect
what is the solution to get the same result in 11
cavity closure seems to have no effect in 11
it is not working
ac11-970 int, ac10, windows xp
9 REPLIES 9
same settings in 11
forgot to mention:
walls & windows are in symbolic mode.
Looks like it's your window's 2D Detail Level -- if it's set to "Scale Sensitive", the 2D symbol is dependent on the display scale -- if you want the AC10 version of the symbol, try setting 2D Detail Level to "Middle" (or perhaps "Simple").
nope it's not that
i've tried all the 2d detail levels - they have no effect on the wall connection. It affects only the window symbol.
any other idea?
(the question was not clear. I was asking about the wall connection. the plan symbol is looking as it should, but the wall connection is not. I am trying to make the exterior skin to turn inside and it is not working. in ac10 it was working. and also the cavity closure in ac11 seem to have no effect.)
vfrontiers
Check your REVEAL settings....
Just a thought,
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
custom reveal is off
and the construction method is the third
I am trying to make the exterior skin bend on the reveal just like the "turn plaster" option, but with a different thickness. the firs picture that i've posted is what i'm trying to get.
any way of doing that?
this is what i'm talking about:
any way of doing it ? (without patches)
there must be a way. it was working fine in ac10
I have the same problen and no find a decide.Pleace help.
I find and other problem:the carity clocery not work in 3d.
The wall in 2d like this:
But in 3d the outside layer of composite is not visible:
