ā2005-08-04 11:38 AM
ā2005-08-04 02:22 PM
sakoad wrote:1) Have you this problem only with AutoCAD Files in ArchiCAD or sometimes also normal *.PLN or *.PLA files are working dramatically slow?
i am always having a problem with speed when i work with dwg and dxf files from autocad in the archicad environment.
ā2005-08-04 08:25 PM
sakoad wrote:With the grouping off, check duplicates. There are millions, for sure. Also, check the fills, check the origin - are you very far away?
i am always having a problem with speed when i work with dwg and dxf files from autocad in the archicad environment. the programme slows down considerably. it takes a long time to finish loading the file and then every command you issue takes a while to execute.
