xrefs
I would like to be able to drag a new 2D xref to line up with an existing xref ie a second floor plan over the first floor plan from autocad so that I can trace my Archicad walls etc. over the autocad plans. I can't seem to line up the two autocad floor plans and move on.
Why can I not move an xref in Archicad?
3 Replies 3
Eduardo Rolon
You can and you should be able to.
xref layers locked?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Shivang Rajvir
Are you trying to have 2 trace references at a same time ?
BIM Transformation Programs | Archicad Workflows | Archicad India Templates
Apple iMac M3 | MacBook M5
Layers were locked. Thank you very much for the info.
