Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
zone stamps in section
Hello everyone
is it possible to have zone stamps in sections.automtically placed..
11 REPLIES 11
Eduardo Rolon
Not completely automated but this one year old workflow is as good as we have for now.
https://4dproof.com/4dproof-blog/archicad-21s-first-work-around/
IIRC Simple AddOn can only read the zone once if it changes then you have to redo it with the label trick it will auto update
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
I checked that blog post and just want to point out 2 important things that could be easily missed:
1. The Zones must be selected in the Floor Plan Viewpoint before going into the Section/Elevation Viewpoint. This will enable the "Related Zone Name/Number" Autotext to return valid values.
2. The Label must be placed with the "Associative" Geometry Method.
