Tuesday
- last edited
Saturday
Hi everyone,
I'm working on a BIM-based quantity take-off system in Archicad 29 and I've encountered a limitation that I can't seem to solve.
I created a Complex Profile Foundation containing multiple building materials/components:
Using a Component Schedule, I can successfully extract each component separately by using the "Building Material / Composite / Profile / Fill" field. The schedule correctly displays each component with its own Net Component Volume.
For example:
This part works perfectly.
I created custom Property Expressions to calculate:
The issue is that Property Expressions only expose the general "Net Volume" (Owner Element Volume) instead of the Component Net Volume.
Because of this:
Inside the Property Expression editor:
IF Building Material = "Brick - Structural"
to limit the calculation to brick components only.
Is there any workaround to:
Or is this simply a limitation of the Archicad Expression Engine?
I'd really appreciate any suggestions, workarounds, GDL tricks, Python API solutions, or BIM workflow recommendations.
Thank you!
