Scott Bulmer
How to change email address for community forum
My profile settings for this community forum are outdated causing info to be sent to an unused account.  In my community settings the outdated email address is shown but I see no way to update the address.  Please advise how to correct this problem.  Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
5 Replies 5
runxel
Try the central Graphisoft ID, where everything is nowadays tied to.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Scott Bulmer
Thanks Runxel, I tried that earlier which did not work.
@Scott Bulmer, PM me your desired new email address and I will change it for you in your User Profile.
Noemi Balogh
@Scott Bulmer you need to change it in your Graphisoft ID. Neither I, nor @Laszlo Nagy  will be able to change it for you.
Noémi Balogh
Staff Community Expert, Admin
OK, so, to clarify it for anyone for future reference:
In a GS Community User Profile, it is not possible to change the email address because it comes from the GS ID.
If a user wants to change their email address, they need to do it under their Login details in their Graphisoft ID Profile:
https://id.graphisoft.com/en/user/edit/profile#login
