‎2021-07-22
02:42 PM
‎2023-05-11
11:02 AM
Noemi Balogh
Solved! Go to Solution.
‎2021-07-24 06:26 PM
‎2021-07-27 04:52 PM
LaszloNagy wrote:Hey Thanks for your response!
Can you use Slabs with Cover Fills?
Then the same element would be used for both the Slab and the Fill.
The slowness issue does not sound good, I will let GS know about this.
‎2021-07-27 07:28 PM
‎2021-07-28 03:51 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2021-08-10 01:45 PM
LaszloNagy wrote:Ah lovely! Thanks for the tipp!
You can set the Slab settings to your desired settings, save it as a Favorite, and use that Favorite in Grasshopper.
‎2021-08-10 02:07 PM
mnguyen wrote:Dear Minh
Dear Lorin,
Thank you for the report and I am very sorry about the issue!
There might be a few reasons why the synchronization freezes Archicad. To investigate further, I would like to kindly ask for your files and the reproduction method for in-house testing. Please let me know if you need a secure place for uploading the files as well.
Best regards,
Minh
