ArchiCAD & Generative Components (Grasshopper+Geometry Gym)
What does ArchiCAD have to do with GC's?
According to Geometry-Gym, quite a bit!
Geometry Gym develop an IFC plugin for Grasshopper,
while Grasshopper have developed the most mind boggling
generative components synthesizer for Rhino(cerous).
Being a BIM architect in this day and age and NOT knowing
of these tools means you have gone missing.
Wake Up!
My final comment is: Who will develop such tools for GDL?
Gil
Links:
http://www.grasshopper3d.com/
http://geometrygym.blogspot.com/
http://ssi.wikidot.com/start
69 Replies 69
Grasshopper is free addon to Rhino3d. You can run it in the evaluation versions of Rhino and save as many grasshopper models as you like (but if you exhaust the 25 model saves in Rhino then it will prevent and plugins from loading). http://www.grasshopper3d.com is a good place to start.
laszlonagy wrote:
Promising stuff.
Automatic Beam Intersections can be toggled by the View\On-Screen View Options\Clean Wall & Beam Intersections menu command.
Hi I've got a issue, in autocad or even in vector works I can create a symbol or object which I can edit and then, modifications are executed in whole drawing automatically. In archicad 15 I have tested "save as component" but I do not know how to edit in order automate modifications. do you know how to do it? Thanks for any help
Eduardo Rolon
Sebastian I think you went into the wrong topic. Anyway what you want to read about in the Manual or help files is either how to create Modules (saving a "3D Block of AC Elements" like Xrefs in autocad), how to Create Objects or how to create Patches. One of those should help you if I understood correctly.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Not sure if anyone at Graphisoft has considered parametric IFC to GDL, but I'm sure it would be more likely if users were demanding it.
Food for thought at this blog post:
http://geometrygym.blogspot.com/2013/10/parametric-ifc.html
That is amazing !
Great job!
I'll try asap.
Thanks Jon
When will Graphisoft finally make a visual like grasshopper parametric editor for Archicad
studio bruce,
Please stop spamming the forum with the same post over and over.
I have reflected to your question on the other thread:
http://archicad-talk.graphisoft.com/viewtopic.php?p=240461#240461
I have also deleted another post of yours that was a duplicate of this post.
stefan
I don't think Graphisoft will make it. Dynamo for Revit was made by an avid end user (who has since been hired by Autodesk). This indicates that the API for Revit was extensive enough to allow this control.
FWIW, I'm working part-time for D-Studio, a Belgian IT & BIM Consultancy company and we have started developing for ArchiCAD recently (they had previous Revit & SketchUp development projects). We have a novel approach to connecting the BIM software to other services. This is not the solution you are asking for, but it will further facilitate the connection from ArchiCAD (and Revit and SketchUp) with other systems, such as Excel, MS Project, Databases, ...
So even if Graphisoft has its own roadmap, at least they have an API with which you can extend ArchiCAD in new directions.
Archicad-user since 1998
my Archicad Book
alexandregrignon
Stefan,
Have you planned to sell this kind of add-on for Archicad (connection to Excel or database) ? I think there is a big lack...
API programming is very powerful but not accessible to most architects who don't have skills or ressources to develop such programs.
stefan
alexandregrignon wrote:
Stefan,
We are looking into that. Right now, it is developed for Client but the technology solution is ours and will be evaluated for possible commercialisation.
my Archicad Book
