Parametric design
About Rhino & Grasshopper and PARAM-O.
Crashing Grasshopper Live Connection
Janmarquito
Hi all,
I am using Rhino 6, the latest version, along with Archicad 27, also at the latest version.
I installed the Live Connection Plugin as intended.
The moment I start the live connection in Grasshopper, Rhino crashes immediately.
It doesn't happen when Archicad is closed, and it also doesn't crash when the wrong port is entered.
I've tried several reinstalls and deleted all the plugins, but nothing helped.
Thanks for the help.
12 REPLIES 12
Dear Tamás!
This is is! Issue solved with the new json file. Thank you!
Is there a way to integrate this file to the installers/maybe some readme file?
Just a little correction for people who read this later: You need to put the new json file in the folder Rhino6\Plug-ins\Grasshopper, no need to complice it into the ArchicadConnection.gha file.
Dános
This works for AC27+Rhino 6.
Thank you !!
Any sugestion for macos? I have the same problem on macos, but I cannot fix it with the help of a dll...
Thank you!
Setup info provided by author
