Creating hotspots in PARAM-O
Hi all,
Is there a possibility to create hotspots on certain coordinates directly in PARAM-O?
Thank you,
Oli
15 Replies 15
RhinoX
I do not agree, Param-O has some limitations in creating shapes but GH-Archicad live connection has limits works to Archicad also, better to use them both.
ryejuan
Hi, I understand that you will use GDL Shape but where will connect the node or just simply place it somewhere in the canvas? Thanks!
WINDOWS 11 PRO
Andras Bognar
That will make hotspot(s) only in 3D, not on the 2D floor plan view...
Is there a way to set hotspots that are visible on the floor plan view?
cuba
As far as I Know, you can only add 2d hotspots in GDL. This works very well in combination with param-o.
There is an excellent tutorial about hotspots on "Barking Dog Bim"
https://www.youtube.com/watch?v=b99b7HBqoiA
Apple M1 Max 32 GB
Latest AC
B_Migito
Hi there,
You can use the same transformation on a gdl shape to get the result you want but it'll still be only in 3D
Shame about 2D but that's all I've managed since I started playing with Param-o
Andras Bognar
Yep, I used this for the 2D Hotspot:
