‎2017-04-04
04:37 PM
‎2023-05-11
11:11 AM
Noemi Balogh
‎2019-01-21 11:50 PM
‎2019-01-22 05:58 AM
‎2019-01-22 12:48 PM
Joe wrote:I personally disagree, Archicad should not be just a documentation software.
This is a common mistake if you ask me. One size does not fit all. Archiad is just one tool in a chain and the way to make that chain stronger is to make using Archicad easier especially in other tools. Personally I do not design anything in ArchiCad and most people I know using Revit dont design in that software either they all design in Rhino/Grasshopper and then find ways to push that into their documentation software.
‎2019-01-22 04:47 PM
‎2019-01-22 08:46 PM
‎2019-01-22 08:54 PM
‎2019-01-22 09:22 PM
‎2019-01-22 10:14 PM
‎2019-01-22 10:29 PM
‎2019-01-22 10:47 PM
For the most part the Grasshopper Components make calls back to Archiad and use the native API to open Archicad dialog s. They could do the same with a GDL component. Especially if they provided a new updated IDE. So in effect they would not need anything specific to Rhino.sounds good, but if you are not happy with the current IDE, then what we could expect in GH... I would be happy to jump to ArchiCAD to write some code if a proper coding enviroment is waiting...
