‎2019-01-22
05:23 PM
- last edited on
‎2023-05-11
11:07 AM
by
Noemi Balogh
‎2019-01-24 05:17 AM
‎2019-01-24 05:21 AM
Moonlight wrote:ah yeah got it. I have had no need for that sorry
@Joe
you're going in the wrong direction from what I have in mind.
I want to extract the values from GDL (values of Pt1X, Pt1Y, Pt1Z from ArchiCAD) that were already used in a model, and inject them to the desired property settings.
‎2019-01-24 05:26 AM
Moonlight wrote:Well with what they have given us you can simply overwrite all values with the correct ones including the existing door.
Real case scenario, imagine having a parametric door, with different models, but only some of these models are complaint, would you like to fill all those properties again and again, or wouldn't you like to automate the process.
‎2019-01-24 05:31 AM
ah yeah got it. I have had no need for that sorryYou don't have say that you're sorry, you're being helpful.
As far as the classification manager and property groups go as I said those can be read in by importing an xml so its really simple to create those if you know how to write out XML.Look, that would be practical if we are talking about few instances of an object, a mechanical copy & paste operation, but if you have huge bunch of them it becomes totally impractical & prone to error, just as you said
this entire workflow is iterative
‎2019-01-24 05:35 AM
Now I suppose what you are going to say to that is you dont want to manually do it so if that where the case personally i would export out a an excel file from an interactive schedule that you setup grabbing only the information you want and read that into grasshopper.Still, this can be practical in cases were we are dealing with few objects, too little or too unique to make an error.
‎2019-01-24 05:48 AM
‎2019-01-24 09:19 PM
