FlappyBird
Get Column Curve
Hi Guy,
How I can get the curve of column from ArchiCad column model same as Beam
I use Deconstruct Column with Column selected from AC model.
Thanks All
3 Replies 3
FlappyBird
I just check again, ANCHOR POINT and END POINT is in m
it is reason to Length of column so very small
FlappyBird
Hi Guy,
Any one can help me
Thanks
Gino Hansen
Hi Nguyen,
Usually this happens when the units of Rhino differ from the units of AC. Check if the Rhino units are set to Meter.
AC 16- AC29
WIN 11 , Razer Blade 15
