Arsenii Bychkov
Grasshopper Connection - Design Options
Hi! Is there any way to set/change option status for ArchiCAD geometry through Grasshopper? I'm working on several massing variants in Rhino and trying to set up a workflow where each variant gets loaded into its own design option in ArchiCAD, yet I can't seem to find a way to set this property through the AC-GH connection components. Even more annoying is the fact that if you set a custom option status manually in ArchiCAD for geometry coming from Rhino, once the Rhino geometry gets updated the option status automatically switches back to "Main Model", undoing all the manual setup.
Would be glad to get any recommendations, thanks!
Operating system used: Mac Apple Silicon 14 Sonoma
1 Reply 1
As far as I know, the Archicad-Grasshopper Connection already supports Hotlinks, but not Design Options yet.
