Parametric design
About Rhino & Grasshopper and PARAM-O.
Grasshopper - Integrate Surface
Josh Verran
I'm using the Grasshopper - Archicad Live Connection.
I have found the surface node.
However, I can't see on any of the tool settings, where I would plug that node into.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
5 REPLIES 5
Gino Hansen
Hi Josh,
This is only available for the Object Settings Node(as described in the user guide p. 63). Surface_GH.png
AC 16- AC27
WIN 10 , Mac Studio OS 12.6
Hi Gino
Thanks for responding to my query.
I've downloaded the User Guide and had a look at p63 - Surface Input Component.
However, it only has one paragraph which says:
"Accesses to the Surfaces attribute set from the connected Archicad project. Currently , this Input Component is available for only the CW Frame Settings and CW Panel Settings components".
In your screenshot though, you appear to have a different object settings node than what I get in GH.
Not sure what I'm missing.
https://help.Graphisoft.com/AC/24/INT/GC.pdf
Also apologies I realize I hadn't included the screenshot of the object settings as well.
Hi Josh,
Try the User Guide for AC 26 : https://help.Graphisoft.com/AC/26/INT/GC.pdf
This will explain how to setup the Object Node.
AC 16- AC27
Josh Verran
Thanks for the link Gino.
I hope I read the sections correctly, you're screenshot above seems to cover all the relevant info with regards to my original query.
From what I understand, the Surface Input Component is only available for the Object Settings Node. Furthermore, it only works when utilizing an existing object (library part), not for creating new Objects. Also, it only works if you do some editing of the GDL code.
I'd add a wishlist item to make the Surface Input Component available for other nodes, but it's likely due to the complexity of the connection as to why it's not available now.
