Nader Belal
Mentor
Grasshopper & Morph
Hi everyone,
I want to ask if there is a way that when I send a number of closed curves to the Morph component it wouldn't form a Morph surface ?
A good friend of mine have once told me that I´m so brute that I´m capable of creating a GDL script capable of creating GDLs.
1 Solution
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
This is not possible right now. If in ARCHICAD you create a closed planar polygon with the Morph tool, then it will automatically be covered with a face. To follow this behaviour, if you create a Morph from a closed planar curve from Grasshopper, ARCHICAD will generate a face covering it. I have let the designers know that this could be revised.
You can of course just unlock the element in ARCHICAD, and remove the face manually.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
Go to post
1 Reply 1
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Regards,
GRAPHISOFT
