Parametric design
About Rhino & Grasshopper and PARAM-O.
Grasshopper & Morph
Nader Belal
Mentor
Hi everyone,
I want to ask if there is a way that when I send a number of closed curves to the Morph component it wouldn't form a Morph surface ?
A good friend of mine have once told me that I´m so brute that I´m capable of creating a GDL script capable of creating GDLs.
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
This is not possible right now. If in ARCHICAD you create a closed planar polygon with the Morph tool, then it will automatically be covered with a face. To follow this behaviour, if you create a Morph from a closed planar curve from Grasshopper, ARCHICAD will generate a face covering it. I have let the designers know that this could be revised.
You can of course just unlock the element in ARCHICAD, and remove the face manually.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
1 REPLY 1
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Regards,
GRAPHISOFT
