2016-12-27
10:24 AM
2023-05-11
11:12 AM
Noemi Balogh
2016-12-28 01:53 PM
2017-01-04 12:30 PM
2017-01-10 06:52 PM
2017-01-11 01:10 PM
leceta wrote:Possibility record from GH in a file (txt, csv) and then reading from a file in GDL, that I use too, in this case me does not interest. At the active change of data in GH you must check to create a new file with rewrite, to bring in data of difficult structure. In ACE you must check a file for existence, to open him, count data of difficult structure etc. It is an only method while, but work with files it is not work with arrays. It is sorry.
array type variables are still not supported in the connection.
You can try to output your lists (arrays) to a txt file, and then read them from GDL. I used this method succesfully to input a bunch of polycurves to archicad, in order to feed POLYROOF command.
2017-01-11 02:51 PM
