2018-08-13 11:06 AM - last edited on 2023-05-11 11:08 AM by Noemi Balogh
2018-08-22 03:09 PM
2019-03-27 12:31 PM
2019-03-28 09:21 AM
[18:55:22] Log started 03/27/2019 at 18:55:22 [18:55:23] Preferred installation mode : win32 [18:55:23] Trying to init installer in mode win32 [18:55:23] Mode win32 successfully initialized [18:55:25] installer_command_line_arguments: [18:55:25] operatingSystemBit: 64 [18:55:25] Check operating system: windows [18:55:25] Variable set: TempForExeFiles C:\Users\a079\AppData\Local\Temp [18:55:25] Variable set: installerEnvironmentVersion 22.0.1310 [18:55:25] Variable set: installerGraphiCDTxt: PACKAGE NAME: GC22-R1-INT PACKAGE VERSION: 1.3 DATE: 2018.11.16. PLATFORM: Windows 7 x64, Windows 8 x64, Windows 8.1 x64, Windows 10 x64 LANGUAGE: ENGLISH (INTERNATIONAL) =================================================== FILE VERSIONS Grasshopper Add-On 22.0.0 R1 (4027) InstallBuilder 18.4.0 Installer 1310 LOC DK, BP =================================================== [18:55:25] Variable set: installerProduct Grasshopper Add-On [18:55:25] Variable set: installerVersion 22.0 [18:55:25] Variable set: installerLongVersion 22.0.0.4027 [18:55:25] Variable set: installerShortVersion 22 [18:55:25] Variable set: installerCountry INT [18:55:25] Variable set: installerSubType FULL [18:55:25] Variable set: installerReleaseType R [18:55:25] Variable set: installerReleaseNumber 1 [18:55:25] Variable set: installerUpdateKey 1 [18:55:25] Variable set: installerBuildNumber 4027 [18:55:25] Variable set: searchARCHICADVersion ARCHICAD 22 [18:55:25] originalWindowsARPRegistryPrefix = Grasshopper Add-On 22.0 INT FULL R1 1 [18:55:25] originalProductDisplayName = Grasshopper-ARCHICAD Live Connection for ARCHICAD 22 INT [18:55:25] originalAllowComponentSelection = 0 [18:55:25] installerRegistryKey1 = HKEY_LOCAL_MACHINE\SOFTWARE\GRAPHISOFT Installers\Grasshopper Add-On\Grasshopper Add-On 22.0 INT FULL R1-1 [18:55:25] Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\GRAPHISOFT Installers\Grasshopper Add-On\Grasshopper Add-On 22.0 INT FULL R1-1 InstallLocation. Setting variable savedInstallLocation1 to empty value [18:55:25] Variable read from registry: Key installerRegistryKey1: HKEY_LOCAL_MACHINE\SOFTWARE\GRAPHISOFT Installers\Grasshopper Add-On\Grasshopper Add-On 22.0 INT FULL R1-1, Name: InstallLocation, Variable: savedInstallLocation1: [18:55:25] Number of previous installations found on this machine (foundInstalledInstanceCount): 0 [18:55:25] Variable set: savedInstallLocation [18:55:25] Variable set: installerRegistryKey HKEY_LOCAL_MACHINE\SOFTWARE\GRAPHISOFT Installers\Grasshopper Add-On\Grasshopper Add-On 22.0 INT FULL R1-1 [18:55:25] Variable set: installedStatus notInstalled [18:55:25] Variable set: savedInstallLocation [18:55:25] Variable set: installerRegistryKey [18:55:25] Variable set: installerRegistryKey HKEY_LOCAL_MACHINE\SOFTWARE\GRAPHISOFT Installers\Grasshopper Add-On\Grasshopper Add-On 22.0 INT FULL R1-1 [18:55:25] FreshInstall Variable set: project.windowsARPRegistryPrefix Grasshopper Add-On 22.0 INT FULL R1 1 [18:55:25] project.allowComponentSelection = 0 [18:55:25] FreshInstall Variable set: project.productDisplayName Grasshopper-ARCHICAD Live Connection for ARCHICAD 22 INT [18:55:25] Variable set: installerRegistryKey HKEY_LOCAL_MACHINE\SOFTWARE\GRAPHISOFT Installers\Grasshopper Add-On\Grasshopper Add-On 22.0 INT FULL R1-1 [18:55:25] Searching ARCHICAD 22 ... [18:55:25] searchMinimumBuildNumber: 4000 [18:55:25] Found ACs: [18:55:25] Found ACs With Old BuildNumber: 220INTFULLR1 {C:\Program Files\GRAPHISOFT\ARCHICAD 22} [18:55:25] Variable set: searchARCHICADVersion ARCHICAD 22 [18:55:25] SearchOtherIBInstallationForSameProduct registryFind result = [18:55:25] Variable set: searchARCHICADVersion ARCHICAD 22 [18:55:25] Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\GRAPHISOFT Installers\Grasshopper Add-On\Grasshopper Add-On 22.0 INT FULL R1-1 InstallLocation. Setting variable foundLocationOfTheInstallation to empty value [18:55:25] Variable read from registry: installerRegistryKey: HKEY_LOCAL_MACHINE\SOFTWARE\GRAPHISOFT Installers\Grasshopper Add-On\Grasshopper Add-On 22.0 INT FULL R1-1, Name: InstallLocation, Variable: foundLocationOfTheInstallation: [18:55:25] Determine local product saved Build Number - savedBuildNumber = [18:55:25] Determine if Update is needed - updateNeeded = [18:55:25] Searching Grasshopper ... [18:55:25] Searching Grassshopper... [18:55:25] rhino5Path: C:\Program Files\Rhinoceros 5 (64-bit)\ [18:55:25] Rhino 5 registry entry exists [18:55:25] Rhino 5 binary exists [18:55:26] Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\McNeel\Rhinoceros\5.0x64\Plug-ins\b45a29b1-4343-4035-989e-044e8580d9cf FileName. Setting variable grasshopperPlugInFileName to empty value [18:55:26] grasshopperPlugInFileName: [18:55:26] Could not find registry key HKEY_CURRENT_USER\SOFTWARE\McNeel\Rhinoceros\5.0x64\Plug-ins\B45A29B1-4343-4035-989E-044E8580D9CF\Plugin FileName. Setting variable grasshopperPlugInFileName to empty value [18:55:26] grasshopperPlugInFileName: [18:55:26] Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\McNeel\Rhinoceros\6.0\Install InstallPath. Setting variable rhino6Path to empty value [18:55:26] rhino6Path: [18:55:26] Rhino 6 registry entry does not exist [18:55:26] Rhino 6 binary does not exist [18:55:26] rhinoFound: yes [18:55:26] grasshopperFound
2019-04-11 04:12 PM
2019-04-17 10:56 PM
2019-04-18 12:34 PM
2019-08-15 02:22 PM
2019-08-19 10:29 PM
2019-11-15 04:50 PM
