Adebar 799
Inconsistant Path when deconstructing objects
Can anybody explain why the anchor points of deconstructed objects don't keep the path/Index of the original Objects?
There are multiple Objects in different paths. The path/tree structure seems to go through the deconstruct component but it won't keep the data.
Regards Ramon
Nurbs
Hi Adebar 799. For me it looks like there is something wrong with your Data Tree structure. Unfortunately I can't see in the screenshot what is on the left side incoming to the "Explode Tree" node. Also the wires show that there is a wrong structure (there should be single wires). Try to sort them with flatten/graft etc. In general you should get what you want then...Data-Tree.png
AC16 - AC29, Rhino 5-8. Alienware WIN 11
