Parametric design
About Rhino & Grasshopper and PARAM-O.
Message opening Grasshopper
felcunha
Hello all,
I didn't notice before, but Rhinoceros give me this message when I run Grasshopper:
The ArchiCADConnection component library was build against an older version of the Grasshopper SDK:
The current SDK: 1.0.6967.16077
The referenced SDK: 1.0.6157.23614
Do you know when the SDK will be updated? Is this the reason for why the connection is bugged?
Thanks,
Felipe Ribeiro Cunha
AC 26, macOS Monterey
1 REPLY 1
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
This shouldn't cause any problems. All it means is that the version we used to create the package for our add-on was an earlier version that is currently out for Rhino. This is going to be the case in most of the times, because they keep updating the SDK pretty frequently (we may publish something this week, and in a few week there might already be a newer one out there).
So this is nothing to be alarmed about.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
