About some problem with grasshopper live connect
Hey guys
I have some problem now
yesterday I use the grasshopper connection in Archicad
but the slab position is very far away from my model that have been build in Archicad
and then grasshopper cracked ,the item that I build with grasshopper was locked
grasshopper was been closed so the item become cannot edit now
how can I fix it
cause the model is very important for me
but I cannot cancel the slab which build by grasshopper....
do anyone can help me?
P.S I use ARCHICAD22 &RHINO6
sorry I'm so stubid
I found the solution
https://helpcenter.graphisoft.com/knowledgebase/86216/
well i think it s because the origin of your rhino file is in the same place as the origin of your archicad file and the slab you`ve built its maybe in the origin . The best practice is to work as close as possible to the 0 point (origin) in Archicad. Anyway, in your case i would just import a few elements in rhino from ac to see the position, or just use the GH connection to get some reference points of where you should build your GH slab, so its in the perfect position.
Good luck.
