Parametric design
About Rhino & Grasshopper and PARAM-O.
Missing archicad-menu i Grasshopper
I downladed an installed a grasshoppper plugin for archicad 24 yesterday. But I get a error message when opening grasshopper. Does anyone know the reason?
1 REPLY 1
runxel
Hero
The Grasshopper SDK version number matches the general Rhino version number.
In this case the one who compiled the binary for the AC plugin had a newer Rhino.
All you have to do is to update your Rhino and you're good to go. There is no kind of "backporting" or therelike.
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
