PARAMO POST COUNT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2024-07-22 12:27 PM
New at paramo, i'm trying to make the number of post parametric without editing in paramo. For example, each post is 8 x 3 xm and the space between them is 3 cm. I would like to reduce or increase the count of post in object property keeping the same value ( post dimensions and space ).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-08-12 12:00 PM
Hello Dany,
Setup 1: Distribute
Dimension 1 will be divided in the number of elements you want. If you change dimension1, the gap between the elements will increase/decrease.
In this option there is a substracion node: end of number distribution = dimension1-width element. By doing this, the object is "stretchable" in 2d&3d
Setup 2: Number series:
In this setup you can choose the width of the element + width of the gap. When you change dimension1, extra elements will be added.
Add this in the 2d code to add hotspots to make it stretchable (select the object/ ctrl-o (command-o)):
Param-o files and gdl-files are attached.
AC27
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-08-12 06:06 PM - edited 2024-08-12 06:17 PM
It could be done differently for sure, but here I am sharing a possible way. Dimension 1 will be the length, Profile A and B the post profile sizes and you could choose the distance too.
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
