2023-08-17 01:07 PM
Good afternoon Everyone!
I am recently using param-o and at the moment I am creating an object, where I have two other object linked together. One of them should be moved along the other to a pre-defined positioned. To calculate the exact position, I need to round up one of the formula results inside the add-on. Is it possible to mark/ add roundings inside Param-o?
Thanks in advance,
Best regards,
Gyula Tóth
Solved! Go to Solution.
2023-08-18 11:08 AM
Use Floor to round down (1,5 will be 1) and Ceiling to round up (1,5 will be 2)
2023-08-18 11:35 AM
Ceiling did the job. Now it works as it is supposed to do so.
Thanks a lot. 🙂
