Gyula Toth
Param-o formulas
Good afternoon Everyone!
I am recently using param-o and at the moment I am creating an object, where I have two other object linked together. One of them should be moved along the other to a pre-defined positioned. To calculate the exact position, I need to round up one of the formula results inside the add-on. Is it possible to mark/ add roundings inside Param-o?
Thanks in advance,
Best regards,
Gyula Tóth
2 Solutions
cuba
Use Floor to round down (1,5 will be  1) and Ceiling to round up (1,5  will be 2)
Apple M1 Max 32 GB
Latest AC
Go to post
Gyula Toth
Ceiling did the job. Now it works as it is supposed to do so.
Thanks a lot. 🙂
Go to post
cuba
Apple M1 Max 32 GB
Latest AC
Gyula Toth
Thanks a lot. 🙂
