License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
Parametric design
About Rhino & Grasshopper and PARAM-O.
Point as 3D hotspot
furtonb
If I would like to use a 3D point from GH (or Rhino itself) as a 3D hotspot in ARCHICAD to snap to, is there a way to do it?
I'm calculating the center of gravity for a set of objects, and it would be very helpful to get it back.
The 3D text could work as well, as I want to represent the overall mass, but it cannot be set to zero thickness. Should I create a new library part that is placed at the center of gravity position, and write the mass value to a property?
(That way I could label it with the Autotext label.)
Any thoughts?
odv.hu | actively using: AC25-27 INT | Rhino6-8 | macOS @ apple silicon / win10 x64
leceta
this should work
furtonb
I was hoping to achieve this in a more straightforward way, e.g. placing the point in Rhino and voilá, 3D hotspot!
