‎2018-06-22
11:44 AM
‎2023-05-11
11:09 AM
Noemi Balogh
‎2018-07-02 07:41 PM
I don't understand your note about control of reference line. What did you mean?kzaremba, i meant that i couldn't (figure out) how to control from grasshopper the reference line location of the wall from Grasshopper. Is always using the input curve as the wall center line. Even changing the default settings for walls. see Figure 01
Have you tried this script on a large amount of walls?I have tried now with 1000 walls, and it takes aprox. 700 ms the total process. 90% of the time spent by "wall parameter" component see Figure 02
‎2018-07-03 03:02 PM
