2020-11-16
11:38 AM
2023-05-11
11:03 AM
Noemi Balogh
Solved! Go to Solution.
2020-12-14 08:58 PM
Florian wrote:
hi
do you see any chance that the Archicad - Grasshopper connection gets similar development and marketing focus like the one you find here listed asthe second topic:
https://www.rhino3d.com/en/7/new/
I see the potentials by integrating the Rhino/GH environment with a BIM application crucial.
BR, Florian
2020-12-18 03:17 PM
The connection seams to be working between ArchiCAD 24 and Rhino 7.0 - but the install process is far from smooth. Here is what I did, if anyone has the same problem:Szamosi Máté
[list=2]download, and install Rhino 6. It only asks for licence for starting the software - which you don’t need
[list=2]install the ArchiCAD connection. It will work this time.
[list=3]the installer puts a ArchiCADConnection.gha file to rhino6/plug-ins/grashopper. Copy it to rhino 7.
[list=4]the .gha will not load at this point, as it needs Newtonsoft.Json.dll to run. It is renamed as Newtonsoft.Json.Rhino.dll in rhino 7. I copied the one from the rhino 6/system to Rhino 7/system. Seams to be working
[list=5]at this point ArchiCAD stopped working. I needed to reinstall it
[list=6]after the reinstall, is seams to be working fine (well at least on the surface)
2020-12-23 12:41 AM
2021-02-24 07:21 AM
alexsks wrote:Can confirm that this is working on my end too. Used the files from Rhino 6 installation folder and just copied them into the Rhino 7 folder. It hasn't given me any errors so far.
For me it worked without problems (AC 23, AC/GH Connection 3007) by just copying these files (to Rhino folder "Plug-ins/Grasshopper").
Newtonsoft.JSON.dll
ProductVersion.xml
2021-02-24 03:09 PM
2021-03-11 11:40 AM
2021-03-12 02:44 PM
2021-03-17 12:58 PM
2021-04-29 08:17 PM
Emil wrote:Did someone try a similar solution for MacOS?
2021-04-29 08:28 PM
