‎2020-11-16
11:38 AM
‎2023-05-11
11:03 AM
Noemi Balogh
Solved! Go to Solution.
‎2021-06-09 10:31 PM
‎2021-06-10 10:27 AM
Czaja wrote:I think what's happening in the background with the advent of the JSON API is quite obvious, programmatically spoken.
Just wanted to give it another try but seeing that there is still no connection to Rhino 7 says a lot about the vitality of this project. Unfortunately...
‎2021-07-14 11:38 AM
‎2021-08-18 11:25 PM
‎2021-08-30 01:46 PM
‎2021-09-09 05:22 PM - edited ‎2021-09-09 05:25 PM
Laszlo, I've recently downloaded a 90 day evaluation license for Rhino 7 on a Mac to see if its something I want to use going forward. I was very excited to see the above post, but I am having trouble getting the connection to work.
This is how the add-on palette appears in Archicad
Any suggestions would be welcome.
Thanks
Stuart Clark
MacBook Pro (Retina, 15-inch, Mid 2014)
2.8 GHz Quad-Core Intel Core i7
16 GB 1600 MHz DDR3
NVIDIA GeForce GT 750M 2 GB
macOS 11.1
Archicad 24 5000 UKI
Using Archicad since 1998
‎2021-09-09 07:44 PM
Unfortunately, I will not be able to check this as I do not have Rhino 7 on my computer and I am not on Mac.
You might want to report this to your local reseller if this issues does not get resolved.
‎2021-09-10 11:36 AM - edited ‎2021-09-10 11:53 AM
updates soon...
‎2021-09-14 09:13 AM
Hi Stuart,
Thank you very much for your question!
From my experience, this issue happens if you don't have the latest update for Archicad 24 installed, which is 6004. Could you please download and install the latest build here and let us know if it fixes the problem?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2021-10-07 09:39 AM
The GH-AC Live Connection for AC25 with Rhino 7 support is now available on the same page.
