Hudson
Rhino and Archicad Cut Fills
I've started to use Rhino 3d for a few custom flared columns.  Is it possible with objects created in Rhino to have cut fills? At the moment I have tried 3ds files and Rhino 3dm files and haven't had any luck with cut Fills? Is this something that is supported? Its getting kind of funky in Archicad having to use 2d fills for cut fills,  lts sloppy.
Operating system used: Mac Intel-based Big Sur
Archicad 24, Rhino 3d 8, 3dsmax 2024 and Corona
Work: Gerard Smith Design
2 Replies 2
Nurbs
Hi Hudson,
Imported rhino objects have no cut fill set as default. But you can change this in the object settings dialogue.
a second option could be the usage of the Grasshopper Archicad Live Connection.
AC16 - AC29, Rhino 5-8. Alienware WIN 11
Hudson
Thanks Nurbs, I'll take another look when I get back into the office.
