Parametric design
About Rhino & Grasshopper and PARAM-O.
Set Multiple Zones in ArchiCAD not working
derekjackson
Hi, I'm having trouble with the 'Set Multiple Zones in ArchiCAD' command when I try to input zones from my model. I have 200+ so can't select them individually, but when I try to drag select the whole lot, it returns me to Grasshopper after the first click, telling me none selected. Any ideas?
http://www.lsiarchitects.co.uk
http://derekjackson.artstation.com
AC19 / 21 / 23 / 27
Windows 7 Intel Xeon 18Gb
Nurbs
Try it in the opposite direction. First select the Zones in Archicad and then click on "Set Multiple Zones in Archicad".
I am used to do it this way when i have to select multiple Elements. You don't have to select them one by one then.
AC16 - AC29, Rhino 5-8. Alienware WIN 11
Nurbs
derekjackson
Works like a dream - thanks!
AC19 / 21 / 23 / 27
