Showing results forย
Search instead forย
Did you mean:ย
Search instead forย
Did you mean:ย
Parametric design
About Rhino & Grasshopper and PARAM-O.
What is correct way to share PARAM-o objects for Public use (Freeware) ?
I made custom PARAM-o object and want to share with Archicad users for free. What is right way to do that ?
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v28 INT / NOR (5030)
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
Miha_M
I never had time to play with Param-o, but I believe it must have equal functionality to Archicad GDL editor in terms of licensing:
If you want to share your work with other users for free, you need to put it under the Public Domain Dedication 1.0.
As for sharing such library parts you can publish them here or on BIMcomponents.com.
| Archicad 4.5 - 29
| HP Z840 | 2ร— E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
6 REPLIES 6
Did you try adding it here? I am curious to know if it works. It would be a good starting point.
Good idea. Will try to upload in separate Tread.
Miha_M
| Archicad 4.5 - 29
This is stretchable snow guard element for roofs with clay tiles.
It have several settings that can be predefined shown in Custom Settings picture.
If its not enough object it self can be edited.
Object consist of these files inside Compressed (zip) folder: Snow Guard.prmo - Param-o file (Import via Param-o manager) Snow Guard hanger Profile.xml - Snow Guard hanger Custom profile (Import via Attributes...) Loading instruction:
  1. Import Custom profile "Snow Guard hanger Profile.xml" via Attributes...
  2. Import "Snow Guard.prmo" via PARAM-O Manager;
  3. Place "Snow Guard hanger" via Object tool in your project;
  4. Check Object settings > In "06. Snow Guard hanger profile" field choose imported "Snow Guard Hanger" custom profile.
    Zip file added as attachment to this thread
Hi   Algimantas
Amazing, I will take a look and I will let know how it works for me.
Thanks in advance and all the best.
Thanks,
Good and Bad feedback is always welcome ๐Ÿ™‚ This is my first parametric Archicad object in my 19 years of Archicad experience ๐Ÿ™‚
