11 favorites to 12 favorites
Is there a way to transfer all or most of my favorites settings that were based off of V11 library to V12 library? It would be quite time consuming to save new favorites in V12.
And or saving a previous template made in V11 to V12 with the V12 library etc?
And I guess the same with layers, line types, fills etc.?
Thanks,
Jim
54 Replies 54
matthewjj
Dennis wrote:
For the record, I do like to migrate my template file from version to version - which includes all the attributes, favorites, views, publisher, model view options, layers, layer combos, etc., but I do start my work environments from scratch (until I research how to show "all new commands" I read somewhere).
Dennis, did you just open your AC11 template in AC12? Or did you use attribute manager to import settings into a 'fresh' file?
p.s. - I agree that a lot of the debate in this thread stemmed from my fast and loose usage of the word template (my bad). For the record, even Karl acknowledged there isn't an official term to describe what I was trying to describe with my 'burrito' template. And had you read my previous comment I explained why I asked for people to post 'detailed' methods for version migration.
matt johnson
archicad since 2004
imac 27, 4.2 GHz Intel i7, 16 GB RAM, radeon 575 4 GB, macOS 10.14.6
imac, 4.0ghz i7, 16gb ram, Radeon M9 390 2GB, OS X El Capitan
matthewjj
Thanks for the helpful link Lazlo! I did notice that some of the links don't seem to be working properly on the ArchiWiki migration article.
matt johnson
archicad since 2004
Dennis Lee
I opened my AC11 template in AC12 and used attribute manager to see if there were new linetypes, fills, and materials that was worthwhile to imprt from the factory AC12 template file.
I already have my pensets, layers / layer combos, and favorites set up the way I work, it's a lot easier to do it this way.
The bulk of my customizing work has been going into setting up the layer combos and favorites - which have layer and pen number stored in them.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
matthewjj
Great post! Thanks Dennis. It's nice to hear how other folks do things. Did you have any trouble with your favorites? Sounded like Jim had a couple of tough ones he had to manually recreate.
matt johnson
archicad since 2004
You are right, two pages don't contain any useful info.
I let GS know.
