Project data & BIM
3D window error
Hi! I have an error each time I open my 3D window in perspective. Each time happens the same: Suddenly all my textures disappear and I have only grey colors and when I activate orbit my objects are in wireframe mode.
So each time I have to remove the program and I am installing it again, it works Ok a while and when I open some projects it happens again.
Anyone knows this problem / error?
1 REPLY 1
Post moved.
The first thing I would try is to update your video card drivers.
It may be an OpenGL issue.
Does the same thing happen if you use the Vectorial (Internal) engine when in the 3D window?
What are your machine specs?
Best to add this to your profile signature so it appears in all posts (profile link is at the top of this page).
