3d Not shown ??
Hello all,
I start my drawing today and it shows every part in 2d but when i switch in 3d , i saw only the top of the parts that are higher then they other. I am suspecting that my level is wrong and i saw somekind of white layer over my drawing so its hiding eveything.
Sorry for my poor English the french is my first language.
Could you pls help me ?
1 Solution
Maybe you are in the Top View and that is why.
In the 3D Viewpoint right-click and select the 3D Projection Settings command from the context menu.
In the appearing Dialog you can change your projection (perspecitve/parallel) etc.
http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/user-interface-reference/dia...
Go to post
2 Replies 2
Thank you master !!!!!!!!
It works again.
Cheers
